Thanks to Phil Zhou for becoming a Knife Steel Nerds Patreon supporter! I’ve started posting early test results for things like heat treatment experiments, retained austenite measurements, etc. on Patreon. The data will eventually be posted to this website, but if you want to see it as it comes then get on Patreon.
Month: January 2019
Does Acidic Food Affect Edge Retention?
Thanks to Bill Wine for becoming a Knife Steel Nerds Patreon supporter!
I was interviewed on the Knife Junkie Podcast, so make sure you check that out.
Acidic Food
Carbon steel knives are frequently used in kitchens, probably the majority of them made by Japanese bladesmiths and knife companies. Kitchen knives cut a variety of foods, and some of them are corrosive. There has been some debate about whether any of these potentially-corrosive foods can actually affect sharpness or edge retention of kitchen knives. Sharpness is controlled by the radius/width of the edge. You can read more in the article on sharpness vs cutting ability.
Which Knife Steels Have the Best Corrosion Resistance?
Thanks to John Scarborough and Robert Angerer for becoming Knife Steel Nerds Patreon supporters!
Update 1/6/2020: I have since performed my own corrosion resistance testing and provided updated analysis.
Knife Steel Nerds 2018 in Review
Here at the beginning of 2019 I decided to write up a retrospective of Knife Steel Nerds so far. A lot of things happened in 2018. First of all, the Knife Steel Nerds website was started, with the first article being posted February 27, 2018. That first article was about a modified 3V steel developed and patented by Crucible but never sold as far as I know. Links to the website were not shared with anyone until March 8th, however.
