Category: Edge Retention
5 thoughts on “Edge Retention”
M398 Steel Testing – Edge Retention, Toughness, and More
Thanks to Joel Sunderland for becoming a Knife Steel Nerds Patreon supporter! And thanks to pog for increasing their support.
The steel ratings table from my new book Knife Engineering has now been added as a Patreon-exclusive with M398 added to the table.
S90V and S125V Knife Steel – History, Properties, and How to Heat Treat
Thanks to Gabe Newell, George Thorpe, Jason, Rogelio Escobedo, Wes Newman, and Wayne Sears for becoming Knife Steel Nerds Patreon supporters! On Patreon there is a new article exclusive to supporters about Artisan Cutlery’s exclusive steel AR-RPM9. The composition was recently announced so I analyzed the composition.
Testing the Edge Retention of 48 Knife Steels
Thanks to Trevor Welch, Theo N, Guns N’ Loaded, EV.Knives, Erik Coccia, Francisco J. Neto, Tristan, Gareth Chen, Alvise Miotti Bettanini, Henjie Taguinod, ben horridge, Steven, and Ian Miller for becoming Knife Steel Nerds Patreon supporters!
Crucible S45VN Steel – Everything You Need to Know
Thanks to John Dyess, Michael Foote, Xun Fan, and Mark Vanderwest for becoming Knife Steel Nerds Patreon supporters!
Thanks to Niagara Specialty Metals for getting me a bar of S45VN for the experiments necessary for this article.
CATRA Tests of M390 Knives
Thanks to Yuval Peleg, Patrck Roehrman, Hugo Costa, and Stefan Stromberg for becoming Knife Steel Nerds Patreon supporters!
CATRA Testing of M390 Knives
Recently two sets of CATRA studies of M390 knives have been reported. One was conducted by Mike Latham of CollectorKnives, and the other by a group of people including Clint of the Alchemy_1 Youtube channel. These reports are the product of a minor controversy over the Rockwell hardness of production knives and the relation between Rockwell hardness and edge retention. Here are links to both reports:
New Study on CATRA Testing of 8Cr13MoV
Thanks to giorgi chubinidze, Luke melley, AJ Munoz, Bobby Best, and Dennis Clark for becoming Knife Steel Nerds Patreon supporters!
Thanks to the guys at Knife Talk podcast for featuring me in the “Community Showcase.” Listen here.
How to Design Knives that Do Not Fail
Thanks to Tom Krein, Joshua Goldstein, Matthew Maola, Edo Vernoschi, Nils Anderssen, and Cedric & Ada for becoming Knife Steel Nerds Patreon supporters!
Failure Modes
A common engineering technique is to evaluate designs based on how they failed, or may fail. Failure modes are identified and the designs are modified to prevent those failures. These ideas are simple in concept but it is surprising how easy it can be to miss the forest for the trees. In terms of predicting failure modes in some cases it is easy and in some it is difficult. You would expect a large chopping knife to require heavier edge geometry to prevent chipping and rolling, or a seawater diving knife to require high rust resistance. Other times failure modes are identified through testing of the knife or by returns from customers. Whatever the source of the failure, there are usually relatively simple methods for fixing each one, though the trade-offs for doing so may not be desirable.
A2 Steel – History and Properties
Thanks to Dan Pierson, Steve R. Godfrey, Bryan Fry, and Timothy Becker for becoming Knife Steel Nerds Patreon supporters!
History
A2 steel is quite old, though determining the exact year it was released is a bit difficult. A2 steel was developed in the early 20th century during the explosion of tool steels that occurred after the discovery of high speed steel which was first presented in 1900. You can read about that history in this article: The History of the First Tool Steel. During the development of the first high speed steel included the switch from manganese to chromium as the primary hardenability element, and most high speed steels had about 4% Cr. That high chromium content was primarily for “hardenability” which is the degree of cooling required to achieve full hardness. A “water quenching” steel has low hardenability and must be quenched very rapidly from high temperature, and an “air hardening” steel can be left in air and it will fully harden. You can read more about hardenability in this article on quenching. The first high speed steel came to be known as T1, which had 4% Cr and 18% W (tungsten). The earliest record I have found of a precursor A2-type steel is in a summary of tool steels in 1925 [1], while summaries of tool steels from 1910 [2] and 1915 [3] do not have any similar steels. Therefore these types of steels probably arose sometime between 1915 and 1925.
Does Sharpening with a Grinder Ruin Your Edge?
Update: Michael Drinkwine sent me another report from Global where they reported factory sharpened and waterstone sharpened knives. I added it to the “CATRA Testing” section of the article.
Can CATRA predict Rope Cutting Performance?
Thanks to Fingal Ferguson for becoming a Knife Steel Nerds Patreon supporter!
CATRA Edge Retention Testing
I previously wrote articles about CATRA testing of edges. The CATRA test uses 5% silica-impregnated cardstock which it slices with a fixed stroke length and force. The first article primarily looked at the effect of edge angle on edge retention; specifically, that edge angle greatly controls edge retention:
How the hell does CT’s xhp hold an edge so long?
Way slow in the reply here, but it has a large carbide volume and can hold high hardness. So, it’s not going to end up that tough, but it will be strong.
I did a plane iron test (for woodworking) two years ago and found it to plane double the linear footage that O1 will at same hardness.
Then larrin posted his results confirming that was in line with catra testing (which was a relief – I got a lot of grief from the woodworking community). What I’ve found since then is that you have to have something relatively easy on the edge (so planing rough lumber will reduce its advantage over more plain steels).
But I’ve made a couple of mules out of XHP for the kitchen and it’s great for low toughness work (and where it won’t lay in salt and rust).
I’m just curious looking at the large steel comparisons, I don’t quite understand, I’ve been told that high carbon steel holds an edge very well but all the high carbon steels on your list seem to be very poor at edge retention. I am just a very uneducated person on this topic who just happened upon this looking for interesting comparisons between knife steels so if I’m missing something or glossing over something on accident I apologize I am just very confused honestly.
Low alloy and simple carbon steels have a small volume of low hardness carbide called cementite. That means the west resistance is much lower than high alloy steels that have more carbide and the carbide is higher in hardness. This is discussed in the CATRA articles and Knife Engineering.
Edge angle and edge retention
I have yet to read trough your entire website, so I’m am sorry if I’m asking something that is already covered.
I have heard that edge angle plays a bigger role in edge retention than steel type does in some instances.
You write that you do all CATRA testing with blades sharpened at 40 degrees (which seems appropriate, for comparisons sake) now to my question. Would not a tougher steel handle a shallower angled edge better than a more carbide-heavy one in the real world. And thereby gain some edge retention in comparison.
I’m personally a fan of
